Please advise on compatible drive recommendation for the 151
Not the driver, but the physical solid state storage device
He is asking which drive do you recommend for the 151. The actual physical drive hardware.
I installed a Samsung 870 EVO 2.5 inch 4TB in my RS150b
it works very well
But does that ALSO work with the 151?
It should. Without issue.
I took the Samsung EVO870 I had on my RS150B and installed on my new RS151 and it works fine too.
