- What D/A chip is here?
- Bult-in headphone amp parameters & spec?
- When upgrade to Tidal Connect feature?
- Can we use iPad Pro for example for USB source purpose? Possible?
- BT keyboards support Y/N?
- I like video functionality, but this is margine, for my the best scenario - music videos, clips from Tidal / YouTube and own NAS. Can you give us more for it: i.e playlists support (dedicated input in app / programmed button on RC…
- Why not ARC/eARC? Without that integration with AV is invalid imo
- Popular multiroom / cinema ecosystem - Sonos… integrate it in yours fw, please!
- Device is very hot when used, strange because external power unit, hot when power amps not work (work anyway?), only stream and cans via jack - hot as hell.
- Apple Music integration? Now its lossless, its hi-res and also spatial… all things marked, so…
Thank you for asking.
- RS201E is include es9018k2m.
- RS201E headphone amp is es9602 and 3.5mm jack , impedance is auto from 32ohm.
- Tidal connect has an upgrade plan. but, now RS201 includes tidal in-app.
- RS201E is not support USB input. RS250 or RS150B is support.
- it working.
- yes. RS201E can using nas with SMB, FTP, WEBDAV. both Remote app or RS201E menu.
- RS150B include ARC. but, not support ARC on RS201E , RS250. because, RS201E and RS250 is small case.
- We are looking for contact points to support it.
- If you do not use a power amp, you can turn off the power amp output in the input/output settings.
- Apple has released the apple music SDK, and we plan to support it.
Best Regards,
+1 for the native integration of Apple Music in regards to have lossless. Using AirPlay 2 is not a solution because it downgrade the signal. Thank you very much.
