Some radio stations to add
Please note some may not work
Some do - haven’t tried them all
Go to radio click + sign enter station name then enter url underneath
Taken off another forum
Mixed - Mother Earth Radio (Germany) (flac 24/96),
http://icecast3.streamserver24.com:18800/motherearth1
Dance - Intense Radio (24/44.1 flac),
https://secure.live-streams.nl/flac.flac
Blues - Radio Bluesflac (flac),
http://streams.radiomast.io:80/radioblues-flac2
Classical - Rondo Klasu Pro (Finland) (flac).
http://rondo.iradio.fi:8000/klasupro.flac
Pop - Chill Out Zone Plus (flac)
http://chillout.zone/chillout_plus 1
Pop - The Cheese (New Zealand) (flac)
http://thecheese.ddns.net:8004/stream 1
Rock - Radio Paradise - main mix (New York, USA) (flac)
http://stream.radioparadise.com/flac
Rock - Radio Paradise - rock mix (New York, USA) (flac)
http://stream.radioparadise.com/rock-flac
Rock - Radio Paradise - main mix (New York, USA) (flac with metadata)
http://stream.radioparadise.com/flacm
Rock - Radio Paradise - rock mix (New York, USA) (flac with metadata)
http://stream.radioparadise.com/rock-flacm 1
Folk - TMEFolk radio (Americana, Folk, Blues, Roots, Country) (flac)
http://ingest-ams.radiomast.io/tmefolk 2
Pop - Knixx.fm (Germany) (flac)
http://s1.knixx.fm:5347/knixxFM_dein…itor_sound.ogg
Pop - Radio 2.0 (Bergamo, Italy) (flac)
https://vps.radioduepuntozero.it/stream.ogg(remove)
Pop - SuperStereo 1 (Chile) (flac)
http://198.204.228.202:8160/flac
Techno - Radio sputnik (house/techo) (Holland) (flac)
http://radiosputnik.nl:8002/flac
Pop - Hi On Line - mixed genre (Holland) (flac)
http://mscp2.live-streams
As long as URL works you can add any radio station by yourself.
Correct, as you may already know .
Hopefully help others who don’t know.
Thanks.
any idea why some only show up if you laboriously paste in the link manually, but not if you search for the station name in RoseRadio?
Hello @Alex_HiRes
If you manually enter the correct URL address in the Radio app, the radio channel will be added to User Channel.
Radio channels in User Channel(Radio app) are automatically synchronized to Rose Radio—>My Radio.
If it does not show, please tell me if you added a radio channel from Rose device or RoseConnect app.
The Soul Central Radio you added for me in the UK doesn’t work anymore.
Hello - could you please re-add Soul Central Radio back into the UK radio station selection please.
It’s no longer working and say http error when I try to load it:
@luxury_scruff
Soul Central Radio only exists in the Radio app. Radio app has been discontinued. Instead, the developed app is RoseRadio.
I found Soul Central Radio’s streaming URL.
Please try
RoseRadio app–> My Radio–>+ button–>Enter the radio channel name in CH name and the URL.
Soul Central Radio: https://www.liveradio.es/http://65.21.202.84:8519/stream
Please let me know if it does not work
Thanks.
It came back with an ERROR_HTTP message but I then refreshed the screen and it was there.
To find Radio Paradise global mix:
http://stream.radioparadise.com/global-flac
