Spotify Connect is not working
With the HiFi Rose RS130, when using Spotify Connect, the music stutters/jerks during the first ~40 seconds of playback. It starts playing, then stops for a few seconds, then resumes — this keeps happening repeatedly at the beginning of tracks.
Additionally, in the Spotify app itself, I cannot select Very High quality — I check the box, but it still plays in normal/ordinary quality and with these stutters.
I’ve tried both Ethernet and Wi-Fi — the issue is exactly the same. I’ve tested with different phones and tablets as controllers — same problem every time.
Other streamers (WiiM Ultra and Gustard R30) play Spotify Connect perfectly without any issues, so the problem is clearly with the RS130.
I’ve already performed a factory reset — it didn’t help.
What could be causing this?
My regular Spotify isn’t playing properly anymore) and I’m not even talking about lossless))) I’m specifically asking about playback in normal high quality…
Sorry, for me it’s lossless.
Sorry I misunderstood.
On Tidal, CD quality is High and Hi-Res Audio is (Max).
Just like on Qobuz.
CD quality is lossless…again, sorry for the inconvenience.
Problem solved. These are new restrictions in our country. VPN solved the problem.
