It is different case than one you described (which is fine by the way).
I’m talking about a situation when the Rose is in StandBy mode and I want to play music on it with AirPlay or Spotify.
In that case Spotify not see my Rose. Same with Airplay. I need to switch the Rose on first, then I can stream my music from Spotify/AirPlay.
In my other audio devices I can stream the music to e.g. Sonos without switching it on.
This looks like a easy fix: do not kill the Spotify and Airplay processes in the StandBy mode. Let them be active waiting for the connection. My Rose RS520 is taking 9W in the standby mode which is pretty high, so running one or two more processes will not change it significantly.
Can you fix that? Right now is so annoying that we need to switch the Rose on before we can stream the music…
