Spotty connect volume
Hi
What is the reason that when playing Spotify from my phone the volume increase in steps of 6?
@Rafic8
If you adjust the volume while playing music on Spotify, you mean +6 / -6 per cell?
Yes, correct
Steps of 6…
1-6, 6-12,…
@Rafic8
In Spotify, the volume can be adjusted from 0 to 15, and for Hi-Fi rose, from 0 to 99 so+ and -6 are normal when adjusting the volume through Spotify.
Hi
Insted of going on the panel of the rose in 1,2,3,4,5 steps when preasing volume up on phone,
It goes from 1 to 6 and 6 to 12 all the way up…
Is is normal?
Not sure I understand your answer
@Rafic8
Yes that’s correct.
