Any suggestion what harddrive i can use in my RS 150b that fits and work? And can i use any external USB cd rom player to rip my cd:s?
The SSD to be built into our HiFi Rose products supports up to 4TB.
SSDs that can be embedded must be 7mm thick in SATA format.
Almost all products can be ripped by connecting an external CD player in the form of a USB.
I used a 2TB Samsung 870 EVO, ripped approximatley 550 CD’s via flac.
Thank you i will order one too
Ive used …this in my rs150…flawless operation so far.
Samsung 860 PRO 4 TB SATA 2.5 Inch Internal Solid State Drive (SSD) (MZ-76P4T0), Black https://amzn.eu/d/gCLR97u
I currently using Melco D100 for ripping CD’s, after a lot of problems with Rose RS780E.
Melco works perfectly with ROSE RS250.
