Standby power on volume
When RS150 set to volume control by software, the standby power on volume is set to the same as turn off volume. We played music in large volume but forgot to low down before turn off, next time will start with a large volume and may hurt the speaker.
Could it be start on a default volume and determine by user ?
Actually I think this may be a polarizing suggestion, I’m curious what other users think.
Some users may find it cumbersome to change the volume setting every time.
Depending on the users particular setup there may be a need for a fixed or variable volume at turn on. This should be able to be set by user, along with a maximum and minimum volume setting. IMHO…
My suggestion is to add a on/off function to set the device could start with particular volume determine by user.
Thank you for your suggestion. We will consider of it internally.
