It looks like configuring the Ethernet interface using a static IP address instead of DHCP causes a buffering issue when using RoseTube and maybe other network activities.
I have confirmed that using DHCP with either WI-FI or Ethernet, RoseTube 4K videos are properly buffered for proper playback. If I configure Ethernet to use a static IP address, 4K videos may halt when the buffer is fully exhausted.
I can see the progress bar when using DHCP has a good advanced buffer (gray bar ahead of the play bar) for smooth playback. Using a static address, the same videos seem to play with no buffer and may halt during playback while it tries to catch up.
@ROSEHAN @ROSELOA Can you guys confirm the playback buffering issue when using a static TCP/IP address?
