Static pop when pausing or manually changing tracks
I am getting a distinct static-like pop whenever I pause or manually skip from one track to another. I notice this particularly when streaming Qobuz or Tidal. Is anyone else experiencing this? Is there a fix?
@jefcrouch I do not have this issue. I have an RS150B and I use it through a preamp. I use it both as a DAC and also through external DACs. None of them have this issue.
Which device do you have and how are you attaching it to your system?
I have used it as streamer, DAC and preamp. I have also used it only as a streamer with an external DAC and preamp. The static pop is present in all configurations.
That is quite strange. Sounds like hardware related. Have you tried different cabling? Have you tried a reboot or even a reset?
In my setup, the RS150B is totally silent when switching content within sources or even when switching the sources - I use it with QoBuz, Apple Music, RoseTube, and SSD internal storage.
Looks like more and more people are having this popping issue. This makes me, @GeorgeLor and @Tony22 @jefcrouch and a few others. Is there a fix underway @ROSEHAN.
I see more issues, any fix yet?
Has anyone got a fix for this? I developed this issue after changing to Weiss dac 204 , rose 130, ra 180 rca out
