I just upgraded my 250 and stock in the “Reboot
system now” I can’t seem to do anything since rose connect cannot find my device. Need help here. Thanks in advance
Would you turn off WIFI(or Ethernet) and turn ON again?
RS250 > Settings > WI-FI or Ethernet -
Do you see IP address here? What’s written?
RS250 > Settings > SystemInfo > IP address
As mentioned, everything hang and cannot do anything. Even rotating the knob is not responding. Here’s the screen picture. Even if I turn off and on the power, it will return to the same screen. BTW, I also tried connecting a USB keyboard, and still no response.
- If there’s something connected to USB port, please plug it off.
- Doesn’t it response as well when you press the power button?
- Have you pulled off the power cable and plug in again?
- Would you let me know the MAC address of the RS250? It’s at the bottom of RS250, starts with D0EB
Hi Roselao,
- None. I have nothing connected to the 2 USB port.
- No response when I short press the power bottom.
- Yes. After putting back the power cord, it will booth up and return to the same screen.
- DOEB9EOC8F89
Thanks!
Would you check the message?
What message? I just send the reply to your 1 to 4 questions.
