Subtitles in Hebrew
Ihave rose rs 150 b purchase from Slovakia and send it to Israel. i try to o run a movie with subtitles in Hebrew but it gives me gibris/ no subtitles at all
Is there someone please can tell me how to fix that? Is there option for subtitles in Hebrew in rose rs 150b ?
Itshak
Would you check these, and let me know if it still doesn’t work?
  1. RS150B > RoseStore > VLC player is on the lastest version
  2. RS150B > Video > Setup > Use VLC Player > ON
Hi Roseloa,
Thanks for quick response.
I will check it and let you now if it works.
Many thanks
Itshak
Hi Roseloa
Sorry, i try and do exactly what you write and it still not working.
The problem is only with subtitles in Hebrew.
Subtitles in English it is working.
Please let me now what to do
Many thanks
Itshak
I will check with ROSE engineers about it.
I will let you know again soon.
Best Regards,
