I have recently borrowed a ROSE 201E to see if it will work in my setup where I have my music library stored on a Synology DS1621xs+ NAS system.
So the Rose has DLNA server capability if an SSD is installed but it does not have DLNA client capability. Accessing my music library on the NAS was going to be a problem. I am unwilling to use SMB v1.0 with all the security issues as proposed by Rose, and even then the Rose would be compiling a database over the network, although 1Gbps, so again not ideal in terms of rescanning performance. My music library has around 21,000 tracks.
So I got thinking â install a 1TB SSD and keep my music library in the Rose as this would be network safe and hopefully the fastest solution for rescanning the database. I had a spare Samsung 1TB SSD 850 EVO to test this. My expectation was to use the Rose WebDav client to copy across the tracks manually. Had a play with this on my Mac after setting up a WebDav account on the Rose and could copy files to the Rose just as if it was a shared drive. WebDav also worked on my windows PC but not as straight forward as the Mac for some reason.
The Synology NAS has âCloud Syncâ and can utilise âWebDavâ â so I set-up a Cloud Sync task on the Synology NAS of my music directory to âUpload local changesâ to the Rose shared â/ROSEDISK/âŚâ directory. I have the Rose unit assigned a fixed IP via my router so the IP address is always the same.
Over my network to copy my complete music library of ~21,000 tracks, 590GB, was going to be an overnight event. Tracks were a mixture of CD(ALAC)/FLAC/MQA files. All were copied overnight in around 9 hours 15 mins according to the NAS logs.
If I add or rename any file on my NAS this is replicated on the Rose 1TB SSD. I can access the music folders directly on the Rose and play them as soon as copied across using the âfoldersâ icon. If I want to search the new files then I need to do a Database Rescan on the Rose.
I set an initial database after installing and formatting the 1TB SSD and this was immediate as no tracks. My first database scan with an empty database after adding my music library took around 38 minutes, for 20,226 tracks. I have just added another album, copied across to the NAS from my PC in seconds. Then for the database rescan to recognise the new tracks, this has taken longer at a whopping 3 hours & 20 minutes, for 20,238 tracks. Whilst it was rescanning the DB, my original music library could be searched â just the new tracks were not in the database awaiting inclusion.
I was curious how long a new DB would take to scan so tested that and for the above 20,238 tracks took 41 minutes.
Have just put my order in for an RS150B in black.
Will see how this all works out as my music library is pretty much where it needs to be in terms of content, and occasionally may add a track or two.
