When trying to enter output setting for the analog output, the system crashes.
Any ideas?
Rick
Any ideas?
Rick
Hi @ROSEHAN,
The analog output is already enabled.
When i enter the settings for that output the system crashes.
I dont have any other problems with settings for different outputs.
System version: 4.19.01
I tried several times to mail you a video of the system crash.
Mail cannot be delivered.
Please let me know how I can sent you the video.
When I saw it, the video size was too large to be transmitted.
Is your RS250a crashed? Or does the RoseConnect app crash?
Does the same symptom appear even if you factory reset your RS250a?
RS250a–>Settings–>System settings–>Factory reset
When sending an email, please compress your video into a zip file and send it.
Currently, we are not experiencing any crashes when setting up the analog output part.
1.Always, since a week now.
App on the RS250 restarts after it happens.
When i try to accces it from my tablet (android) the app on my tablet stops.
Running the latest versions.
Rick
Please check a few additional things.
If the same symptom appears even after factory reset, please tell us the Rose ID of your RS250a.
RS250a–>Settings–>System info–>ROSE ID
