Hello
every time I switch on my RS 520 this information comes up
I noticed this after the last update
Hello
When will the software team fix this?
In this update, optimization features have been added to run the service more stably.
There is no optimization process when standby mode is used, but it is implemented to perform the process of optimizing storage and memory areas when completely restarting.
In the future, we will make the optimization process smarter to reduce the optimization time.
If the optimization process is cumbersome, we recommend using standby mode.
Thanks for the info
But the action would be nicer if it would run in the background
best regards
Jörg
What does the optimization mean in detail?
Is it just a database optimization or is it also a file system checkup thing to avoid file access issues?
You can think of it as a phrase for stabilizing functions including database optimization and file system checkup.
