Technics VU Meter needed
Is there any chance to add VU Meter like in old Technics amplifiers? Something like this:
Regards
@Basstech
There is a similar Vu as shown in the picture below.
Do you want the Vu- meter exactly the same as the picture you showed posted?
These VU-meter doesn’t display on full screen.
“Do you want the Vu- meter exactly the same as the picture you showed posted?”
If it wouldn’t be a problem so I think yes.
Let the rest of the users speak.
Regards
Really looks very nice, will be nice add to Rose 250 with a EQ, then the perfect product.
Kr
Full screen VU meter is great, 20 channels EQ is most i want. thx
Picture from Volumio forum - peppy meter
Can You make this VU on fullscreen?
Hello Hi-Fi Rose users
We recently made a lot of fixes and additions to the Vu-meter functionality.
Currently, we are working on fixes in order of stability for other features.
When it stabilized, we will be able to pay attention to the Vu-meter screen.
Wonderful Technics style vu meter…
Is it possible to buy it?
Many thanks
