Terrible Bluetooth Connection on RS250
Anyone else experience terrible Bluetooth connection with the RS250?
Please, no comments about why someone would use Bluetooth on a HiFi Rose. As a bedside set up for headphones, there are times at night that I want to send the audio from my Apple TV 4K to the RS 250 via Bluetooth so I can listen to TV through my headphones and not disturb my wife. That is my use case scenario.
Having said that, I find that the Bluetooth connection on the RS250 is spotty at best. Sometimes the sound will completely drop out or lag, or just struggle to stay connected.
In contrast, when I switch over to my Wiim Pro Plus from my Apple TV 4K, it has a rock solid Bluetooth connection that actually sounds really good.
Why is the Bluetooth connectivity on the RS250 so crappy? Anyone else have this problem or do I just have a fluke bad unit?
Thanks for any insight you can offer.
@StrangerInParadise
Currently, we are not receiving any information about Bluetooth.
Does the same symptom appear after factory resetting your RS250?
RS250–>Settings–>System settings–>Factory reset
