I noticed that the inscription 150b in the upper left corner is covered. Is it possible to fix it?
The phrase “ROSE - 15” on the top left of your RS150 is the device ID, not the RS150.
It will be easier to understand if you look at my products.
Is this now called the serial number of the device?
Why don’t you try renaming your device?
I changed the name the day I set it up.
I’m speaking for an RS520, I can’t say what it looks like for other Rose products.
Yes, we need to see what can be done! Thank you!
