When playing HiRes files from Tidal on my RS130 the stream is interrupted frequently (sometimes every few seconds).
The firmware and apps are all the latest version (5.7)
I have tried the following things:
-enabled caching
-static IP or DHCP
-different DNS
-WiFi
-factory reset
-ethernet is stable, all other applications run without problems (600Mbit/s)
-streaming from Qobuz works without showing any buffering issues
-Rose radio and playback of tracks from the internal SSD works without issues
-logging in and out from Tidal shows no effect
-Tidal settings are correct
-setting time and date to manual shows no effect
Any suggestions on what to try next?
