Tidal Connect missing
Mostly listen til Tidal HiRes.
I just placed my HiFi Rose RS520 in a vodden chest because of the missing Tidal Connect.
When using the remote I can’t see the screen from my listening position and the remote has an awful delay ajusting the volume. Beside these problems I like RS520 very much.
I have now bought a new product that have the features that RS520 is missing.
Sad that HiFi Rose has not been able to find a solution to these technical problems which even much cheaper can manage.
Hope the company will find a solution.
Best regards
@010529
We are working hard to support Tidal Connect. However, Tidal does not provide any help.
We have to solve that problem ourselves. Please understand even if it takes time.
@Czaaart
We would like to add Tidal Connect and Spotify Connect but it is not possible at the moment.
We are trying to add them when we get the chance.
Thank you again for your advice.
The Tidal website contains the following advice for those “ Partners” who wish to add Tidal Connect to their hardware:
“Hardware Partner Application
We at TIDAL currently do not accept any in-house applications for TIDAL Connect. If you are interested in integrating TIDAL Connect into your hardware you can do this through our 3rd party integrators.
TIDAL Connect certified integrators:
My question - is HiFi Rose currently in contact with any one of these three “ certified integrators” of Tidal Connect ?
@Martini
Yes we are in contact with StreamUnlimited to get the hardware components and APIs we need for testing.
We are still in development so give us some time.
@Czaaart
The method we are currently planning to make it applicable to all devices.
We will let you know when the details are decided.
Ich habe den Tidal RS 150B neu. Ich bin sehr enttäuscht und echt verwundert, dass dieses teure Gerät nicht Tidal Connect abspielen kann. Jeder Streamer für ein paar hundert Euro kann Tidal Connect.
Dies ist, als ob man ein Auto kauft ohne Blinker mit dem Verweis, man kann ja mit der Hand winken.
Sicher kann ich über die Rose Connect App Premium auch Tidal in der gewünschten Qualität hören, aber viele Informationen, die Tidal bietet, z. B. die tägliche Vorlschlangsliste oder die Liste der wöchtentlichen Neuererscheinungen u.v.m. sind über die Rose App nicht zugänglich.
Hinzu kommt, dass mir die meisten Funktionen inder Rose App Premium ein Rätsel sind. Wie lege ich z.B. meine Favoriten in einer Bibliothek an. Es wird damit geworben, dass dies möglich ist.
Die Bedienung der App erschließt sich in den meisten Fällen nicht von selbst. Hier finde ich kein Handbuch. Auch das Handbuch des Streamers beschreibt den technischen Bereich sehr gut, hört dann aber auf, wenn es um die Bedienung geht.
FatBob,
There is no manual for operation of the software. A major failing particularly since the software, although stable and complete is not intuitively arranged.
@FatBob
Currently we do not support Tidal Connect.
Tidal Connect is expected to be supported sometime later this year.
The Tidal in the RoseConnect app is based on the API they currently support for us.
If you have any questions about using Tidal in the RoseConnect app, please contact me.
Ich habe keine Ahnung, wie bei Rose Connect Premium Favoriten gespeichert werden.
Wenn ich Songs speichere, sind sie gespeichert eine Weile da, zum abspielen aufgerufen werden können sie nirgends, dann sind sie wieder alle verschwunden. Bei der Rubrik Musik tauschen einige abgespeicherte Videos auf, sonst nichts, bei der Rubrik Video taucht nichts auf, bei der Rubrik Privat
taucht nichts auf und so weiter. Wie soll man hier eine Bibliothek aufbauen? So ein Mist
@FatBob
The video below is related to Favorite. Please refer to the link below.
Nach wie vor fehlt der direkte Zugang zu TIDAL Connect. Darüber hinaus habe ich beim Abspielen von TIDAL über die Rose Software immer wieder Probleme, dass Songs nicht richtig abgespielt werden, weil sie ständig aussetzen und nachgeladen werden. (Pufferprobleme). Da ich ein sehr schnelles Internet habe, das Gerat am LAN angeschlossen ist, kann es an der Internetverbindung nicht liegen. Ich vermute, es ist ein Fehler im Gerät ROSE 150b. Viele haben in der Community schon dieses Problem gemeldet. Sehr ärgerlich, dass ein so teures Gerät solche Probleme verursacht, jeder Billigstreamer kann es von der Technik her besser. Ich hoffe, dass Rose endlich dieses Problem kurzzeitig löst. Der Zugang zu TIDAL Connect war für Ende des Jahres zugesagt. Wir haben nun Ende des Jahres.
Unfortunately, Tidal Connect isn’t supported; that’s just how it is. I use Qobuz, which works both in the Rose app and with Qobuz Connect.
You can create favorites in the Rose app under Tidal/Qobuz by tapping the heart icon while listening to an album. The album will then appear under “My Qobuz/Tidal” in the Favorites folder.
You can prevent dropouts by assigning the device a static IP address and connecting it via LAN cable. A switch box directly at the device is also helpful. I initially experienced dropouts (with a 15m LAN cable) and now use a Bonn N-8 directly connected to the RS-250, and I haven’t had any buffering problems since.
Hi Matterhorn. Could you please go into a little more detail about what you mean by “dropout?” In my experience using Qobuz Connect the first couple seconds of individual songs get dropped when playing consecutive songs in “Album Play” mode. It seems like the latest update has fixed this but I sometimes still have the first few seconds of the first song dropped when I select a new album. Were you experiencing random dropouts mid-song or only at the beginnings of songs like me? I would have thought the built-in buffering capability would prevent this from happening.
I have an RS130.
@Eleven
The first few seconds of interruption when using Qobuz Connect no longer occurs with Version 5.9.09, which we use.
Could you please provide the Rose Model, output DAC information, and version information you are using?
Please send us a video of the problem when playing Qobuz Connect to the email address below, and we will review it.
shim1691@citech.kr
Initially, I had some issues with the buffer; the orange bar would jump to the right mid-song and playback would stop. After assigning a static IP address and adding the Bonn N-8 switch, the problems disappeared. For over two years now, I’ve been enjoying Qobuz and internet radio in excellent quality without any issues.
