Hoping someone can help. My RS150B is connected by Ethernet directly to my modem and I also have my Roon Nucleus + connected by usb to my RS 150B. The Nucleus is also connected via Ethernet to my router.
If I select the usb input to play Roon playback is flawless, no buffering but I don’t get to experience the beautiful display. I’ve tried streaming Roon from the app and using the RS150B as the input and I get rhe display but buffering is terrible and lots of gaps and silence in the stream, skipping tracks etc.
If I try using Tidal or Qobuz from within the HiFiRose remote then it’s better sometimes but I still have issues. I really want the benefit of the display which is a big reason for buying it in the first place but it’s unusable due to the buffering.
My broadband connection is fine, speeds are great and I stream 4K Netflix etc without issue. I don’t understand why I have an issue streaming Tidal to the RS150B when it’s being fed by an Ethernet connection.
I’m using IOS version of the Rose app and have the same problem whether or not I use my iPhone or IPad Pro
