Hi, i have some troubles with Tidal.
Impossible to search, go to my palylist etc…
I have à loader…
Best regards
Please check the following points:
Have you logged into your TIDAL account in the RoseConnect app?
Do other streaming apps work normally besides TIDAL?
When you select TIDAL in your RoseConnect app or Rose device, what screen appears?
→ Please take a photo and send it to me. -
If you go to the RoseStore on your Rose device and reinstall the TIDAL app, does the same issue still occur?
I clean, install and is OK thank you !!!
I’m glad to hear that the issue has been resolved.
If you have any further questions, please feel free to contact us.
