Tidal has trouble with audio cache. There is a limit to the cache size and its varies depending on the songs. After playing for certain amount of time, Tidal stops to cache up (the time varies).
The problem only happens when using Network Switch → SOtM sNH-10G with sCLK-EX clock, while using RS150B.
The problem disappeared when using different network (TP link) with RS150B.
Is there a way to fix the problem with the Network switch stated above?
