Tidal Playlist Sort Options
When importing my playlists from Tidal to Rose, My Tidal, the default sort order in my RS520 for the name of each playlist folder is “Registration Order” .
I can switch to “Name Order”, my preferred option, but after closing the app and returning to it the next time, the sort order is automatically back to “ Registration Order”.
As a preference, why can’t the sort order for playlist folders remain permanently in “Name Order” rather than having to change it each time I log on?
@Martini
The default sorting function in Rose devices is Registration Order.
The sorting function changes back to Registration Order when you close the app.
Sorry, but the only way is to change it to “Name Order” when entering the app.
Thank you for the quick reply.
I know it’s not the biggest issue out there but, with this restriction, sorting imported Tidal playlists is just a little less convenient than it otherwise could be !
