Tidal Playlist Synching Issue
I am seeing differences/playlists missing from my Tidal/Apple direct apps vs the HiFi Rose app.
A playlist is syncing from Tidal to the HiFi Rose, but the synced playlist only contains 134 selections on the Rose vs 140 on his Tidal app.
@Woody
  1. Of the 140 playlists saved in Tidal, if you synchronize them to Rose, will only 134 playlists be transferred?
  2. Even if you turn off and re-enable the sync function and sync, the remaining 6 playlists are not synced?
Correct. And sometimes the Playlists don’t sync at all.
I am having problems with Tidal playlist syncing and would also like know how to sync with Apple music
I did find the way to enable sync but it only seems to be 1 way from Tidal to Rose and there does not seem to be a way to sync with Apple Music. Are these comments correct?
