Tidal stops every few seconds, there is buffering, it is impossible to use it normally, on another device tidal plays normally, so it’s a rose problem.
Here are a few things to check.
- Do you experience the same symptoms when you re-login to your Tidal account in the RoseConnect app?
- Do you play tracks from other music streaming apps on your RS250a normally?
- Does this happen with a specific music source when the audio source is interrupted in Tidal?
- Do you experience the same symptoms when you factory reset your RS250a?
RS250a–>Settings–>System settings–>Factory reset
