Hi. I have been the owner of rs150b for a week. Initially, for the first 2 days, I had no problem playing music from Tidal. After updating the software - I can’t listen to a single track without my music stuttering multiple times - it’s really annoying. I tried changing the ethernet cable inputs, checked the internet connection and it is the same all the time. The piece begins, then pauses for a few or a dozen or so seconds, and so on. It’s the same on Rose tube. Internet radio works fine, and so does YouTube. I have a Yamaha wx10 and the Tidal works there without any problems. I am asking for help in this matter.
P.S.
I still have a problem with the rs150 remote control. The first time I was able to pair it with a device. Unfortunately, after a few hours, I lost the connection and attempts to pair the devices multiple times did not work. Any suggestions?
plawgo
I have the same problem. Do you have a switch between the 150B and the router, how fast is your internet connection. I had to switch to WiFi.
I connect to the internet using a Netgear switch. Link speed: download 45 Mbit / s, ping 17 ms, upload 19.8 Mbit / s.
just tested for you guys. I have no issues using Rose app and playing tidal. Never use the rose app hence I like Roon better. Did you guys also update the app it self? Not that that should give any stutter.
Switch to WIFI and then back to Hard connection.
Deze volg ik niet helemaal. ( hard follow what you mean )
