TIDAL track/album info lost
Why can’t I find the track info (credentials, composer, producer etc) when I play Tidal through the Rose app?
In the tidal app I just click on the album picture and it displays this info.
Why don’t you support Tidal connect?
@janhelin
First of all, Tidal Connect support is still under review, but it seems difficult to add.
Like Tidal Connect, you can check track info in the RoseConnect app.
If you look at the picture below, please scroll the screen to the top on the song playback screen. Then you will see your track credits. Please check the song information there
Thank you for answering. Very helpful!
Best regards
/jh
