Hello there. I just recently noticed that my Tidal wont play continuously, its buffering too long. I never had this problem before. Is rhere something i can do or you can do? Thank you
What’s the ROSE model you are using?
Are you using ethernet?
When did the issue start to occur?
Can you tell me the Rose ID?
(Rose streamer > settings > Rose ID)
Hifijune
It happened 5 days ago. Thank you
- What’s the ROSE model you are using?
- Are you using ethernet?
- Can you tell me the Rose ID?
Thank you,
RS250
Im using wifi
RoseID 0B97B1
