tidal on rose 250a is different to whats on my samsung tablet and phone makes difficult to control with rose connect app.so Bluetooth takes over so i may just as well send tidal straight to my amp but not the solution, also on the weather issue can Brighton be added to the city list
We do not currently support TidalConnect.
We will try to support it in the future, but it is not certain.
The menus supported by the RoseConnect app and the TidalConnect app cannot be the same.
We support functions through the API that Tidal supports, so please understand that it cannot be the same as TidalConnect.
Finally, the Brighton area has been added.
how do i turn n on spotify on rose 250a
If you look at the upper right corner of the RS250a home screen, you can activate Spotify by turning the icon in the part I marked in red in the photo below into white.
Go into the Spotify app on your phone, search for the device, connect it to your RS250a, and play Spotify music on your phone.
The music will be played through the RS250a.
