Time for a 2024 Wish list?
Seperate preamp are best for doing room calibration/correction. Anthem AVM & MRX have Arc Genesis – it is incredible.
I don’t advise a HiFi Rose unit be an All-in-One ← All-In-One unit’s cannot create reference level for everything required in an Audio System or in a Video System.
Bluetooth connection of PC or Mac keyboard to be able to type in disc info/track titles instead of using screen.
Shortcuts and aliases on home screen. User friendly, convenient. Saves a lot of click to go to the inputs screen, and have to select “OPT IN”. Let me place a “TV” hyperlink on home screen instead. Or a radio station directly on homescreen “SKY” for instance. If volume setting then also could be added to the link settings it would be heaven !
We don’t need every Stremaing service.
Also Roon does not brint every service on its platform, this has nothing to do with progress, special quality.
Keep dreaming.
If you need it, that’s ok, but not everyone needs it, quality comes first.
I too desire sound quality - that’s my prime reason for my interest in the RS130. My NAS does not have albums. It has individual songs named “Artist - Song Title.flac”. All files are organized in folders named by genre, mood, occasion (e.g., Relaxing, Fun, Party, Dining, Rock, New Age,…). Songs on streaming services are all organized by playlist (this my wish #1) – hopefully, there’s an easy way to create a playlist for each of my NAS Folders and to list streaming service playlists with the Rose Playlists. As for #2, there’s only two interconnect ways to connect the RS130 to my Anthem AVM 90 prepro (either Digital Coaxial or i2s) – i2s is my preference especially in hope that in the future RS130 will support surround sound (SACD,…) and 3D sound (Amazon Music, Apple Music, Blurays like Hans Zimmer Live in Prague,…) ← I now found a cable manufacturer that can custom build a pin configuration compatible to my AVM 90; hence no longer need #2.
#4 was requested because of all the RS130 User Interface comments/bugs and slow scan/rescan comments.
#5 onward are wish items for my use cases.
I do agree with you, fix problems first (like the PLL 10 second issue, etc) and maintain (or if possible, improve) sound quality.
Joyofmvid,
I also have an Anthem AVM and an RS 130. Can you please let me know who the cable supplier was for your custom cable build and what they charged for the cable?
I haven’t yet purchased the HiFi Rose RS130? I’m still doing research.
For custom pin configuration i2s HDMI cable, see https://www.aliexpress.com/item/4000255873784.html?srcSns=sns_Copy&spreadType=socialShare&bizType=ProductDetail&social_params=21093606133&aff_fcid=5d53334ec865429fbc79eb433f36bc9d-1717016112874-05850-_mLuh8Do&tt=MG&aff_fsk=_mLuh8Do&aff_platform=default&sk=_mLuh8Do&aff_trace_key=5d53334ec865429fbc79eb433f36bc9d-1717016112874-05850-_mLuh8Do&shareId=21093606133&businessType=ProductDetail&platform=AE&terminal_id=0609428eba7544908e676db9a22eda62&afSmartRedirect=y
I’m currently contacting Tubulus to find out if the do custom pin configurations.
I’m currently waiting for Anthem to notify me the Anthem AVM 90 pin configuration.
As soon as I know more, I’ll let you know.
BTW, I just found out that i2s carries only 2 channel sound (ie, stereo). Hence, it was recommended that I use the RS130 's HDMI output to connect to my AVM 90 (thus, permitting surround sound & 3D sound). My question is the sound quality difference between RS130’s i2s Out and HDMI Out.
For great Tubulus i2s cable review (custom pin configuration), see Tubulus Concentus I2S | The Ear
@StandardModel, Tubulus also does custom i2s pin configurations (at no extra charge) – see https://www.tubulus.net/
I also found a USB to i2s converter with four pin configurations – see GUSTARD U18 USB Interface
My next step is to get the pin configuration for the Anthem AVM 90 prepro.
Joyofmvid,
I had a Gustard U18 with a Gustard r2r r26 but swapped them for a LAiV which has multiple i2s configurations selectable by software.
Flash,
Yes, I use the LAiV’s balanced outputs. They feed an Anthem AVM70 8k.
I’m not a musician or a reliable judge but they sound significantly better to me than my Gustard r26 r2r previous DAC. I find the ESS and similar chip based Dacs to be very “accurate” but harsh sounding. The Gustard - as all r2r Dacs are - is more natural sounding. I also liked their “space” or spreading out of the sound field beyond the speakers. The LAiV is similar to the Gustard in those respects but just more so to my ears.
I would enjoy being able to add Pandora.
Requesting a Multi-Channel/2-Channel Audio Toggle:
Recommended port cable setup,
  • User can toggle the Multi-Channel Button/Icon ON or OFF.
  • If user desire’s to play music “as is”, connect RS130’s HDMI port to TV/Preamp.
  • If user desire’s to play music in “2-Channel only”, select a 2-channel port from the 2-channel group’s set of ports and connect the selected RS130’s port to the TV/Preamp
HiFi Rose:
To implement the above, rename the Passthrough Option to Multi-Channel and create a display button/icon for user to toggle this option ON or OFF.
When the user toggles the Multi-Channel option, the RS130 turns on mute, then switches the audio port (as shown below), then turns off mute. (The Multi-Channel Icon then indicates the new Multi-Channel On/Off status.)
If Multi-Channel is turned On,
  • Audio is sent on HDMI port
** If source media is audio (e.g., FLAC file, RoseRadio or music streamer’s output), a Black Screen is sent as the HDMI’s video stream
** If source media is a video (MKV file, RoseTube,…), the source video is sent as the HDMI’s video stream.
If Multi-Channel is turned Off,
  • Audio is sent to the user pre-selected 2-channel port (within the 2-channel group’s set of ports; ie, AES, USB, Digital Out, i²s)
New Wishlist: When the user setting “increase content info” is enable, put Artist on the left-side of the 2d line and after “Artist” put the song’s metadata in brackets – ie, this is the metadata shown on the default view front panel display, in top-left line.
If insufficient room to display song-title or artist-name, truncate with two suffix dots
(ie, truncated-title…)
Does the “Front Panel” have a designated name? Is this referring to what is displayed on the actual front panel of the device or does it refer to the music/video/radio station playing screen on the device? I’d like to refer to the music/video/radio station playing screen by its correct name.
In my view, this screen, whatever its name Radio Screen should be the default central screen of Rose devices after a selection is made to play a song, video or radio station instead of this:Rose Selection .
Additional wish for 2024:
  • Database & GUI to be “metadata centric” (ie, metadata driven/focused")
  • Make use of double-linked lists and single-link lists to drive displays
  • To speed up rescan, use files’ “last edited date/time”
  • For GUI enhancement, permit users to create Dynamic Lists & to do Advanced Search (see Plex’s Dynamic Lists & Advanced Search ← these are powerful user tools)
  • Consider supporting m3u playlist files
Why not just use roon? Does everything better and works great with HiFi Rose
My reasons are as follows.
Many community members said the RS130 player has better sound than Roon’s. In addition, AFAIK for my use case, Roon features doesn’t warrant the monthly price and the extra $$$ to create a Roon Server.
I have done a bit of google/YouTube research – it looks like to create a Roon Server, it’ll cost me about $2000+ Cdn. As for the UIF, I know Roon is great to find out history & recordings of various individuals like producer, guitarist, etc. As for Roon’s playback UIF, I don’t think Roon:
  • creates user specified/controlled dynamic lists (based on metadata)
  • offers Advanced Search capabilities like Plex
  • has Lists such as of all Playlists – that’s all my NAS M3U Playlists with all Roon created Playlists plus playlists from all subscribed music streaming apps
  • has any features supporting music videos
Todate, all my music & music video playback has been via:
  • playlists (including other member’s public playlist)
  • dynamically created metadata lists sorted by user selectable list columns
many community members said that fuses and cables make a difference, too. That’s because (M)any community members are idiots. Like people who think that RS130 has any sound. It does not.
Aperfectly workable Roon server can be built for about ~USD300-500. And that’s if you do not have some old unused computer, in which case it is free.
Of course it does not support music videos, it’s an audio playback system. For people who are serious about music, it’s the best available system (not to say that there’s no room for improvement). For people who are more interested in boasting how much money they wasted on useless audiophile crap, it’s not really necessary.
