Time not correct
I’m using RS130. I found an interesting error from my machine. The clock is always not correct!!! even the time zone is correct. 1-hour error is displayed. If the time should be 8:30, my machine only show 9:30. I cannot set it manually.
I had the same with my RS250a. It was solved when I put “Daylight saving time” to on.
Maybe this helps for you too.
@juno2889
Here are a few things to check:
  1. Where do you live?
    RS130–>Settings–>Date and Time–>Time zone settings
    Is the GMT time set to the same as the country you live in?
  2. RS130–>Settings–>Date and Time–>Daylight saving time–>On
    If you change the Daylight saving time setting to ON as above, will your RS130’s time be off by 1 hour?
I recently tried factory reset. Everything became normal again😆
When I put my RS130 into standby the clock is one hour late, when I start and put it to standby again the time is right, I have done factory reset and the problem is still there. I also loose the Spotify connection now and then and I need to push the three dots and put it on again manually?
@Gorsti
Where do you live?
We also apologize for the inconvenience caused by the occasional disconnection of Spotify and the need to manually restart it.
This issue may also be caused by instability in the network environment or a temporary error within the Spotify app.
We will forward this issue to the development team so that they can improve the connection to ensure a more stable connection.
Hi! I live in Sweden, today everything is correct again. I have another small issue, can you give me an instruction to set a firm IP adress to my R130? I use IOS and everytime when I start my app I have to manually choose the RS130 at the bottom of the screen under where my Iphone shows up, the when I push complete I’m in again?
@Gorsti
To set a fixed IP address for your RS130, we recommend assigning a static IP through your router’s settings. Look for a “DHCP reservation” or “Static IP” option, and bind your RS130’s MAC address to a specific IP address.
This will help your iOS app find the RS130 automatically without needing to select it every time.
