Track skipping after unpausing a track
Hi, every time I pause my HiFi Rose 150b and then go back to the track later on and u pause the track it only plays a few seconds more and then skips to another song - why, and can this be fixed?
@dtalwar
To give you an accurate answer, we ask you a few questions.
  1. Does it mean that if you pause music while playing and then play it again, it will go to the next song after a few seconds?
  2. Which music did you play? Qobuz, Tidal, Rosetube, etc.
  3. Does this symptom appear in a specific sound source?
  4. When you pause the music being played, what did you pause? RoseConnect app, RS150b, BT remote?
Please reply.
The problem occurs with Tidal via my iPhone 14 pro app. If I pause a track, then say watch TV the. Return to the track later via the Rose app, it plays a few seconds then skips to another track. I mostly play Tidal MQA music as it sounds best.
