Is there a Trigger out function on the Hifi Rose RS150? I do not see a 12v trigger. I’m considering to use the RS150 as an Pre-amp/streamer in setup with two Michi M8 amplifiers. As the entire setup is standing out of sight and i just want to use Tidal to select te RS150 and start streaming, i’m wondering if the device will automatically turn on the M8’s or is a trigger function is a necessity and how a trigger funtion would work in this combination?
KISS= keep it simple stupid ,
So come out of one of the 5v usb’s on the rose rs150b with a 5v to 12v step up , into a 5.5mm to 3.5mm mono jack , works a treat . KISS
This works on the usb of 150b too
This solution doesn’t work with an RS150B. The USB ports on the RS150 don’t behave like a trigger because power is never interrupted (unless you physically unplug and reinsert the USB cable). There are options to control whether a USB port is on, off, or auto during standby, but that only applies to the data connection. Power is never affected by this setting.
@ROSEHAN Are there any third party solutions that could address this?
