Hi
I’m trying to connect my 150B to an external DAC via USB
I’m getting error message that there’s no DAC
The cord is ok, worked with the PC+DAC
Do you have the DAC active = On
Sure, on USB input
Still not recognized
I had the same problem, I rebooted and just flipped out the USB on Rose and put it in again directly , the the dac was recognized.
How do I reboot? I unplugged it from the power for 2 minutes without any help
Take a look for example here
→ not all USB cables (e.g. had problems with different cables from oehlbach) are working with rose devices.
I still didn’t understand which cable will work 100%
I’m not gonna buy endless cables until I’ll find the right one…
Supra excalibur working fine
