Which application within Roseconnect should I be using for internet radio. Are they both being supported? Is one better than the other. I find them both difficult to use. Is there a good tutorial for using the best of the two. How would I remove the app. I don’t use?
It doesn’t matter if you install and use both RoseRadio and Radio apps.
If you want to listen to the radio, we recommend using the RoseRadio app.
Lastly, for apps you don’t use, go to the RoseStore app on your Rose device and uninstall the apps you don’t use.
