UK Radio Stations To Add - Please
HI, could you please add the following stations to the UK section please:
Thanks…
Did you try to ad them yourself?
Yeah I did - didn’t work
You have to insert the address of the radio player, not the website of radio.
For the channels above, I just added so please check.
Hello - they all work fine, except for the one I really wanted.
Soul Central Radio on the RS250 is pointing to a radio station called Central FM (a totally different radio station).
Could you please try adding this station again? Might be worth removing the one that is listed as this station too.
Thanks…
Please check again ,
Perfect - thank you so much for doing that, it is appreciated…
