Not sure what is happening, but my rs250 doesn’t seem to show up in the iOS and iPad app. When it does, it disconnects after a few songs. I also tried WiFi and ethernet, both gave me the same results. I am using the latest iOS app version and latest update v4.19. Please help
- If your RS250a version is 4.19, you need to use the RoseConnect premium app. Are you using an app that says rose in gold letters on a black background?
- Is your network running smoothly?
- Does the same symptom appear even if you delete and reinstall your RoseConnect app?
- Are your iPad and Rose device connected to the same IP network?
Rose device—>Settings—>System Info—> IP address shown in IP Address and Wi-Fi IP connected to your phone Up to two points must be same.
Example) Correct
iPad IP Address: 192.168.4.33
Example) Wrong
iPad IP Address: 192.168.6.33
Please take a picture of the screen showing the IP address
I am using RoseConnect Premium app. My network is smooth, I moved from Spain to Dubai and the setup hasnt changed. I tried deleting and reinstalling, no change. Screenshot attached on the IP.
The ip on rose is 192.168.68.110. I have it connected to the ethernet cable. Wifi is off.
Please check one thing.
Even if you delete and reinstall the RoseConnectPremium app, you still can’t find your RS250a?
No, I have tried multiple times.
Can you please help?
Sorted it out, I had an issue with my router. Thanks
