Are SACD ISO supported? I have downloaded few albums but rose is not able to play either of them.
Any help will be appreciated
I am on the lastest firmware on Rose 150b
It’s totally supported, but you have to enter via folders. The database cannot add the iso files.
Regards!
I am unable to play even if I go through the folder mode
In the case of SACD ISO sound sources, Rose devices process it like CD playback.
Since the ISO format is a CD Image standard for Rose devices, it enters CD playback mode and plays it as if playing a CD directly.
If you try to play another sound source while playing an SACD ISO sound source, a pop-up will appear that does not end CD playback.
If you want to listen to other music, end the SACD ISO sound source and play another sound source.
SACD ISO is not registered in the album even if media scanning is performed.
You can listen to it by directly selecting the desired ISO image from Music → Folder.
If you want to use it by registering it in an album, you must load the ISO image, rip it, and save it as a DSD file.
Thanks. I will try and let the forum know
