As i’m mainly using an external dac with my RS150, today i was not able to get any analog output from the internal dac (yes output was selected).
I only tried the unbalanced, not the balanced, but absolutely no sound, i checked the volume was set to max.
Only after a poweroff of the unit, with the external dac turned off, i was able to get analogue output.
Please check.
