I noticed a few times that upon power on the output is set to hdmi.
I only use analoge output, no hdmi connected even.
Why does the output reverts to hdmi?
I have the same problem on my RS250 since the beginning. It happens a few times per week for no apparent reason.
Grtz. Hendry
Does it happen even after latest update? (4.1.03)
If you didnât update to latest version yet, please check if it happens even after latest update.
Also, please let me know your current version with issue.
(RS250 > Settings > SystemInfo > System Version Info > View Details > ROSE OS > ??)
Hi, it did not happen since using the latest update.
If it happens again i will let u know.
Regards and thanks.
Hi, here didnât happened it also after the last update.
I will let you know if it happens again.
Grtz. Hendry
Hi, just to let you know as promised, that today my RS250 has changed the analog output to the hdmi output by itself.
This was the first time after the last firmware update.
System info: ROSE OS: 4.1.03
Grtz Hendry
Sometimes when you boot ROSE device, even if the screen is on, the things in ROSE devices may not be ready. (They take more time then LCD)
So please give some time for RS250 after booting.
Still, that shouldnât happen⌠I will request for double check.
So, when you looked at the IN/OUT Settings, it was on HDMI OUT and you couldnât listen to music without changing the output, did I understand right?
I have seen the same behaviour. It started after the latest SW update.
If I use analogue output and turn off the RS250 to stand by and later turn it on, it sometimes switches to HDMI output by itself.
After I turned off âHDMI pass troughâ (I think it was called) in HDMI out settings, I have not had the problem.
Best regards
/Niklas
Hi, you have understand correctly.
When I hear no music after starting up the RS250 from the standby position, I check the in/out settings on the RS250.
Then I see it has changed to hdmi out and I have to change it back to analog out.
This happens despite I have the hdmi out settings turned to âoffâ.
Yesterday, this automatc change, happened twice.
Grtz. Hendry
Same issue for me on RS250. Happens a couple of times per week. Rca and coax out are only cables connected.
Hello Max,
Do you see it changed to HDMI when you power up to RS250?
Or while you listen to music, the music suddenly stops and IN/OUT setting is changed to HDMI by itself?
Hello Roseloa
It is when I power up. Same as other comment - I start playing something and get no sound. I check the settings and see that it has switched to hdmi.
Hello Max,
Currently, the latest version for RS250 ROSE OS is 4.1.06.
Did it happen in 4.1.06 as well?
Also, whatâs your ROSE ID?
(RS250 > Settings > SystemInfo > ROSE ID)
Thank you,
I have the latest OS installed. No experience with previous OS as I have only had it for two weeks.
Rose ID: OC86B8
We will try to solve the issue through update.
I apologize for any inconvenience.
All of a sudden this has started to happening againâŚ
Yes this is happening. Not resolved with update. Turned RS250 on to play radio to find no sound then realised setting had changed to HDMI - not the first time unfortunately. Letâs see these niggles iron out please slowly becoming annoying.
Iâm sorry if you had the issue again.
Would you check these for me?
- RS250 > IN/OUT Settings > HDMI OUTPUT menu > HDMI passthrough > ON or OFF?
- Whatâs your ROSE ID? (RS250 > Settings > SystemInfo > ROSE ID)
My HDMI Passthrough is set to âOFFâ
Rose ID 0B99BF
Thanks for your quick response
I havenât had this problem for a few weeks now until today.
My RS250 has changed itself to the hdmi output.
My Rose-ID 0AE2F9
Grtz Hendry
