Update 4.4 (Info)
I’ve just received and updated to Version 4.4
Would like very much to know what are the differences and/or new implementations.
Could not find any info at the Bulletin Board…!
Thanks and Happy Christmas
You should find the release info on the RS201 itself in the news.
Also checked it, but the only info shown there is the date of the update, how to install it and the designation OS 4.4.02
No, you must go to the news (click on the mail icon on the start screen → not using a rose app) and there you can find in the newest message the whole release notes for 4.4 while scrolling down.
Thanks. Was not scrolling because the corresponding scroll right bar is not shown at the beginning.
I still think that the contents of this new update should appear here at the Bulletin Board (just like the previous versions).
Upgraded my RS250 from 4.3 to 4.4. Now Im having issue with Rosetube. It becomes very slow. Playing already on the display but on the TV its not playing.
@gpvillacorta
If the Rosetube is playing slowly, you need to check the network status.
If the Rosetube video does not play on the TV, there are several methods.
  1. Make sure that the TV button on the top right of the screen where your RS250 video is playing is turned on.
  2. Check if the TV external input is properly set.
  3. Set RS250–>Settings–>Display–>HDMI resolution to a lower resolution and try playing.
Thanks! Everything is working fine.
