Update release for Rosetube / RoseConnectPremium / RoseConnect
Dear HIFIROSE users,
We fixed Rosetube issue for Rosetube / RoseConnectPremium / RoseConnect.
Please update before using Rosetube.
Date: August 16, 2022. PM 17:00(GMT+9)
Update for:
  1. RS150B / RS250 / RS201(E) - RoseConnectPremium
  2. RS301 / RS350 - RoseConnect
[Update]
  1. Fixed Rosetube playback/share/search error due to Youtube policy change.
1. How to update for RS150(B) / RS250 / RS201(E) - RoseConnectPremium
  1. RoseTube : Rose device > RoseStore → RoseTube → Tap “Update” and proceed with the update (Ver 4.2.21.33)
  2. RoseConnectPremium: Update RoseConnect Premium on PlayStore (Android) (Ver 4.2.21.3)
2. How to update for RS301/RS350 - RoseConnect
  1. RoseTube : Rose Store → Rose Tube → Click “Update” and proceed with the update (Ver 1.6.15.23)
  2. RoseConnect: Update RoseConnect from PlayStore (Andorid) (Ver 1.6.15.1)
Hello Rose Family,
on my rs250, the update doesn’t work.
The update procedure is running endless and doesn’t find an end.
Kind Regards
Mike
Hello there
same issue here, update procedure does not complete whatever the method used.
RS - 150 btw
Ook precies hetzelfde als bij mij blijft maar lopen
In Switzerland the same Issue, the Update running and running and find never the end.
The same thing here in Canada. The update cannot be completed. I have an RS150B.
The same in Portugal, on the RS250!
same same , no update
We are checking the issue with never ending update.
I apologize about the issue.
If someone can upload the photo of the issue, it would be helpful to double check that the issue fixing now is the same one with yours.
Fixed suspicious cause, please try update again.
Once again, I apologize about the issue.
Best Regards,
It’s still not getting updated on my hifirose rs150. The update never seems to end
Would you let me know your region and ROSE ID?
(RS150B > Settings > SystemInfo > ROSE ID)
Same problem with my brand new RS150B.
Rose ID: 0CBADB
I’m in Ukraine
Sama is israel,
The update never end… And keep spinning
Hello @vladisakov and @Rafic8 , would you check the message I sent you just now?
Hi
Just reply
Hi! Just sent you a requested info
Thank you!
For those who can’t update, please unplug the power or shut it down completely, and then turn it on again.
Best Regards,
Does the update work with this method? I’ll try it tonight and report back. Thanks.
Hello, Rafic8 solved the issue by update after unplugging the power cable and power on again.
Hope it works for you too.
Bests,
@ROSELOA
unplugging the power cable and power on again worked for me too
