Upgrade to new firmware
I can’t upgrade my Rose 150B to 4.6.07???
Can somebody help me? Internet connected with ethernet Cable.
Do you see the message there is an update available?
Yes, but it is impossible to download the update.
I have the same problemen.
Try turning off the device and wait for about a minute and restart again. See if it helps.
Dear user
If you send the model name of the Rose device you are using to the email above, we will send you an email including the update file and update method.
