When connecting the RS130 to a external DAC using the USB audio out option is the clock of the RS130 completed bypassed and the DAC’s clock is the only clock that is used?
If I understand correctly the only way to use the clock of the RS130 is to connect the 130 to your DAC via i2s or AES / S/PDIF or coax ? Is this also correct? I2s for my current DAC is not an option so I am left with AES / S/PDIF or Coax unless I am wrong and the USB audio out also transports the clock data from the 130.
Thanks in advanced
