USB B input has low volume
The input volume when switched to USB B is really soft. the set up is: Aurender ACS10 ->USB B Input ->Hi Fi Rose XLR out → MICHI X5 . The Aurender has no volume control, and when I use the USB out from the Aurender to the Michi via the same USB cable, there is no drop in volume.
I have the volume maxed, What I am not seeing is a specific volume for the USB IN.
@ROSELOA - Any chance of getting the USB input to have a :“volume settings for each source” entry? I see individual settings for multiple items including both applications (Tidal, Quboz, Apple Music, etc.) and connections (CD, BT, Aux, ARC, Opt, Coax, AES). My content ripper/manager only has a USB out.
Actually it is for using the USB out on My Aurender ACS10 into the Rose (acting as a dac), which is then connected via XLR into ML 523/534 Pre/Po that I bought to replace the X5. AES is also digital, yet is has a volume setting for source. Source volume settings allow (at least in theory) all sources to be relatively even in output.
JamesByrnes, I’ve had this problem, USB out from my MacMini, my solution was to set the Fixed Volume, Exclusive Mode on in the Tidal, Amazon, Roon software. I assume the Aurender Conductor software has a selection like this.
Billy
