Hello guys
I’m looking to find out exactly what the USB-c port on RS150 can be used for?
I tried to connect a Sandisk external SSD and it is not detected by system upon boot.
Do you know if there is plan to use it in a future update?
TIA.
Chris
Hello guys
TIA.
Chris
Hi @Kryss,
Do you know RTFM?
As explained in the manual, page 55:
USB-C port is only for service
Another location in the manual, page 15, says:
USB-C(update): This port is used for system updates.
Hope this can help.
Christophe
Hi Christophe
I pretty much know RTFM, but as a geek like you should also know, we don’t like to do that
Anyway tks a lot for pointing this out. I was suspecting something like this. I guess I’ll have to find an adapter to connect my Sandisk 2TB on USBA ports.
Cheers.
Christian
