i just received my RS150 and eager to use it, however i’m using an external R2R DAC via USB (Musician Pegasus).
While high res files work fine, DSD files are not played in DSD Native mode even though that option is selected in the USB Dac output screen.
Any suggestions ?
Also, is there a way to power down USB ports when the unit is powered down, this actually shuts down or wakes up DACs that detect USB power is available/unavailable.
There’s also an issue where external USB dac is not being detected when it’s powered after the RS150.
