In the audio-setting of the RS-130 is a setting called ‘USB DAC-nonificatie’ . It comes next under ‘VU-meter reference’.
This ‘nonificatie’, I guess, is some translation from Korean into Dutch but I don’t quite understand it, it is not in the Dutch dictionary
. My guess is that it should be ‘notification’, so the RS can read the actual name of the connected DAC?
I can’t find what the setting does in the manual. I think it is set to ON ever since I bought the RS130 and connected my USB DAC. I do not want to experiment just to find out what it does because the RS130 works fine as it does (that is also worth mentioning on this site were there are a lot of complaints rightfully posted).
Can anyone tell me what the setting does?
