Usb hhd/ssd current demand
if TWO hdd./ssd are powered up by the 150 unit will the internal psu be able to cope with the current
Why not use a powered USB hub?
always use powered in the past, but now cant seem to find 2 tera with psu they all seem portable/usb fed thanks
You can connect a powered USB Hub, connect it to the Rose USB port and plug it into AC Power. Than connect two or more drives to the hub.
